avoid cheap chinese brands. When I recapped my LC III, I used all tantalum capacitors for the logic board by Vishay Sprague, but electrolytics should work fine too. Also, don't forget to recap the power supply, use only electrolytics for the power supply. I had to have mine finished and fixed by Amiga Of Rochester because I'm crap at surface mount soldering, but if you're confident enough, I believe in you. And be careful, it's very easy to rip pads on these old boards if you're not careful
