Ok, I got a very nice-looking Performa 475 with a network card, HD, VRAM, RAM — but missing the PSU.
I temporarily added a known-good PSU from another LC.
The capacitors look fine. I even removed one to check underneath, and it confirmed no visible leakage. A very very nice board!
Boot time: happy chime, HD spinning, that nice old sound of the moving heads… but no video. The monitor’s LED turns green, yet it reports “unsupported mode.”
I tried a PRAM reset — nope, no luck. Then I replaced the VRAM with a new set from Silicon Insider. The originals were 80ns, and so are the new ones. (The old ones, by the way, are from two different manufacturers.)
With the new VRAM I got video, but with vertical bars. I tested different video modes: only thousands of colors worked perfectly. I figured my VGA adapter must have been set correctly only for that mode.
I then added BlueSCSI and created an image of the HD — lots of good applications were on it.
Next, I tested the floppy drive, which worked fine at first. But all of a sudden, it showed the same behavior I had with the old VRAM.
Tried another PRAM reset — no way. I put back the old VRAM and got video with the vertical bars again. Swapped back to the Silicon Insider VRAM and… “unsupported mode” — though the HD was still booting. WHAT?
I grabbed another known-working LC 475, added the Silicon Insider VRAM… and no way!! What the… have they been fried, or what?
At this point I need to take a break from the frustration and have a beer.
But I’m left wondering: could the real culprit be those “nice-looking” capacitors, and should I replace them?
Any thoughts?
Any thoughts?
