And isn't that what it's all about?it’s getting used now rather than being a broken motherboard in a draw.
What happens if you remove the jumper?the id is normal 840av as I’ve put a jumper on the led connector![]()
Have checked this yesterday while I had my case open and the jumper makes no difference, it IDs as an 840AV (ID 78) either way. Curious.I seem to remember it just ids as a macintosh, could be wrong tho.
The 8100 was wired without the ID loop back, the 840av might be the same. Where there isn't a desktop and tower version I guess the ROM doesn't need to know.Have checked this yesterday while I had my case open and the jumper makes no difference, it IDs as an 840AV (ID 78) either way. Curious.
On the logic board? I.e. are the middle pins on the male connector wired to anything?840AV has the loop as well
they likely made the LEDs as a standard part, so it is whether the logic board has those pins wired to anything that is the interesting bit - on the 8100 they're not wired to anything, on the Q800 and PM9600, 8600 and various others like the IIvx (!) they are.
Makes sense, like the 8100 it doesn't have a desktop version of the PCB.Just pulled out my spare board to look. I can't see any traces leading off from the middle pins of J29. It's possible the traces are internal but more likely they're not wired to anything given the ID doesn't change.
The weird one is the IIvx/vi. There is only the desktop version, but they considered making a tower - the IDs for it are in the SuperMario source. I wonder if the Finder shows a tower icon on my IIvx if I plug an LED harness in? (In 7.1).
