MAC Plus Sad Face 03c510
What joystick?  I hope it's not one from a PC or literally any other computer or gaming system.  The only joysticks which will work with a Mac /edit/ pre-USB / are ones made for a Mac.  If you've somehow plugged another type of joystick into the back of your Plus, there's every chance you've fried something.
What joystick?  I hope it's not one from a PC or literally any other computer or gaming system.  The only joysticks which will work with a Mac are ones made for a Mac.  If you've somehow plugged another type of joystick into the back of your Plus, there's every chance you've fried something.
Basically this with a db-9 connector.  Certainly an Apple product made in the early 80s
I'm positive a chip(s) is fried.  Hopefully deciphering the error code can point me in the right direction.
That's the Apple Joystick II, isn't it?  IIRC this is a DB9 connector normally.  I think you're right, this isn't compatible with the Mac.
Edited my reply above: USB controllers are of course compatible, it's the older, proprietary ones you have to watch out for.
As far as I remember, every Mac game controller pre-USB used the ADB port.
