Major Personal LaserWriter NTR Woes!!
Scott Baret
68LC040
Having some major Personal LaserWriter NTR woes here!!
First, the paper almost ALWAYS jams. I've tried thicker paper (i.e. resume paper) and it works a little better, but I just can't get this to feed nicely. Based on some feedback I've gotten, this is almost certainly the rollers going. I'm not sure if anyone has made a replacement part or if there's an HP equivalent.
Second, my NOS toner doesn't print. I'm chalking that up to it being old and being stored in too many different climates since I got it, from my trunk to a basement to a garage to my office. I did order another toner (which appears to be MUCH newer; it's an HP 75A that I snagged for under $20 on eBay with free shipping so it's not a huge gamble). My guess is that my toner is just no good. I also am wondering if Apple still does the recycling program for these toners, as there was a UPS label in the box. I may actually ask an Apple Store tomorrow about this (if not, I'll just take it to Staples). The cleaning document from the printer install disks didn't work either.
Third, this is the weird one, it keeps printing the same document over and over and over and over and won't communicate back to the Mac I'm trying to print on. I've ruled out a few things. First, I've done this on two different Macs now, which were both AppleTalked to the LaserWriter--an SE running 6.0.7 and an LC running 7.1. I tried first on the SE, which had the LaserWriter driver that came with 6.0.8/7.0 on it. I used the version from 7.1 on the LC, which came out after the NTR's release. I also used several programs, including Word 5.1, TeachText, and Kid Pix. All had the same problem. When the printer ran out of paper, I didn't get an error on the SE (which was running single Finder) but did on the LC (with Print Monitor). The SE eventually threw up an address error after After Dark came on. Command-Period did stop the printing. Out of curiosity, I installed a fresh copy of a newer version of the driver on the SE--to no avail.
(to make matters worse, the SE's Quantum drive, which I've owned since 2001, gave up the ghost a few hours later; thankfully, I had a spare Quantum on hand to hold me over until I get two BlueSCSIs for these machines, which will likely be next month, and was able to restore the system easily from the other BlueSCSI I have for a Mac Plus in my lab).
The entire goal of getting this printer up and running was to reliably print a Print Shop file. I wound up resorting to a trusty old ImageWriter II. Since when has going to an ImageWriter from a LaserWriter felt like an upgrade?
I'm guessing the LaserWriter is going to be a long haul project at this point.
ImageWriters II will last forever. They will be the cockroaches of the electronics world after the apocalypse.
Believe it or not, I had one of the newer ones (the II/L) die two years ago from a bad power supply!! I found a donor for it though; the donor had a good print head and power supply but must have been in some bad conditions based on the plastics and the fact the foam inside was disintegrating.
The ImageWriter II that I used tonight is one I've had for 33+ years now...
I had a LaserWriter IINT and while it was in very nice condition and had a low page count (4000), every toner I used smeared and left tons of toner dust inside the printer. I ended up selling it to a local member here sometime ago; not sure what became of the IINT.
My ImageWriter II and LQ are still going strong (though the LQ has a cracked plastic cover from when it was shipped - still looking for a replacement after 15 years). With the exception of the color ribbons, the black ribbons don’t degrade as bad as toner and ink cartridges do.
Regarding the rollers: Friction can be restored by cleaning them with rubber rejuvenator (something like 25% methyl salicylate and 75% isopropyl alcohol - easier but more expensive to buy it pre-made).
A timely bump because y'all might be the only other people in the known internetverse having similar experiences to myself. I have a Personal LaserWriter NTR -- and I've almost made it live again. The challenge is far, far, far more difficult than you might expect.
Full write-up here:
I think I'm about one "replacement toner" (not cartridge - those "exist" but they are lies!) away from actually having a working printer. And from the looks of things online - I may be the only person in the world that's seen a recognizable/coherent test page come out of that printer in quite some years. So close to the finish line...
Now I just need to figure out two or three major hurdles:
1) Toner that isn't stale (any compatible cartridge made for this printer has 15-year-old toner at best - it's all bad by now)
2) A proper replacement doctor blade for the cartridge (VHB tape "works" but ... isn't quite to spec)
3) A proper replacement wiper blade or solution for the drum cleaning (having proper toner that doesn't erratically stick to the drum might actually solve this on its own)
At this point, somebody needs to reverse engineer toner cartridges for the LW series (there are people building ribbons for the ImageWriter II).
Any NOS toner you find online will all have the same smearing problem.
I'm also thinking about _how_ toner degrades. It honestly feels a lot like moisture... I think I might give dehydrating a try (high-ish "low" temp, at PLA drying levels). Might bring life back to old toner? It definitely seems like uncharted territory... not a lot of people care about discontinued toner, nobody's really ever talked about it. Otherwise, the (original) toner's just going in the garbage, so how much worse can it get? :)
