There are at least four production versions of the Macintosh II logic board that I'm aware of. I'd be interested if anyone has a board other than the ones listed below.
Macintosh II 820-0163-02
I don't have this board. The next set of images is from Bruce at Branchus Creations. This is the earliest board I'm currently aware of.
It has a bodge pull-up resistor (+5V->100 kilohm->RxD+ modem serial receive pin) presumably to prevent the board from accidentally entering burn-in-diagnostic mode.
It has axial tantalum and electrolytic capacitors. It does not have the surface mount electrolytic capacitors that plague the most common Macintosh II board.
The capacitors all seem to be populated, including those beside the Apple Sound Chip (U72 below).
Macintosh II 820-0163-03
I have two of these boards. Comparing the photo of the -02 board to my -03 boards, the boards seem identical. I assume either something on the back or something else I haven't spotted is different.
The -03 board also has the resistor bodge at top. Why wasn't this fixed between the -02 and -03 board?
Similar to the -02 board, this has a set of PAL chips for NuBus control. The later Macintosh II board uses a single NuBus chip.
Like the -02 board, the -03 board does not have surface mount electrolytic capacitors. However, unlike the -02, Apple doesn't seem to be consistently populating them all. For example, C11 and C13 are missing in the image below.
And all of the capacitors beside the Apple Sound Chip are missing on one of my -03 boards. They are all populated on the other -03 board.
There is a factory bodge on the back of the board. Someone forgot to run ground traces!
Interestingly, Apple was still shipping the defective 342-0105A to 342-0108A ROMs as recently as the the -03 board revision. These ROMs are apparently quite rare, as Apple recalled them due to a bug in accessing more than 1 MB of NuBus space. This would have constrained 24-bit video cards, for example.
The 342-105-B ROMs fix this bug, and the 342-0639-A/B/C ROMs offer FDHD floppy support. So, the A ROMs were largely replaced.
On the -03 revision motherboard, the battery footprint does NOT include the ability to add standard commercial battery holders directly on the board (without a carrier). That is, there are only two holes for each battery.
For comparison, this image from a later revision shows two extra holes for each battery holder, along with a big hole for the battery-holder-polarity-alignment peg.
Macintosh II 820-0163-B
As of at least this board revision, Apple fixed the resistor bodge, the underside capacitor ground wire bodge, and added the holes for battery holders (which they unfortunately didn't use).
Surprisingly, most components got renumbered. For example, C136 is now C3. U31 is now UB1. This is really strange, as most of the components are still the same -- just numbered differently. This makes repairs more difficult, because when someone says "check C3" I can't be sure we're talking about the same C3 unless I know your board revision.
(post continues)
(post continues)
