Hi,
I’m souping up an early stock Transwarp GS accelerator to hopeful 12-13Mhz.
Part of the process is to upgrade the WD65C816 CPU to a later revision.
How do you get it out? I can’t see clips on the top frame, there are two large holes on either corner I thought you maybe insert something to lever it out. Or should it unclip somehow?
Thanks
Thanks
