Just finished a recap of what was a working SE/30. No bomb but some leaky caps. Now I get Simasimac on the screen and no bong. I do get some static via the audio jack on boot. I have NEC VRAM chips if it matters.
I have reseated the ROM and the RAM. I have checked continuity on all the pins for UB10 and UB11 and they check fine. I reflowed the pads on UE8.
What's next?
Does anyone have an easy way to check continuity for UE8 and or the VRAMs? Is there a way to test if UE8 is good?
What's next?
