Advice with SE30 restoration
It was $20. And I have learned A LOT playing around with it. Also good to know that my RTC is not necessarily bad. (There was no bomb and all the traces tone good.) I am back to poking around in the UD8, UE8, UE10, C2, and C7 area. Debating with myself wether to put the original UDB and UE8 back in or wait for the Mac Peeker board I ordered to arrive.
I’m mostly concerned about previous report that chips are hot, that something is shorted.
When I run one of my SE/30s logic boards for a hour or so outside the chassis I can’t feel heat from any chips
It is normal for some of the chips to be warm on the SE/30 especially in open air without cooling. In particular the video PALs in the center will *always* be hot. Here's a series of thermal images.
Check if each chip is in the right place. There’s an ID on each chip. It matches where they have to be. I don’t have access to this file right now (away on a vacation), but you can find it on the internet. It indicates where each PAL is located.
You are right - I let one of my boards run for a few hours and the PALs are quite hot to the touch. Do they need little heat sinks? I don't think I've read many or any posts about the PALs failing.
Nah, they're perfectly happy to operate at that temperature forever. They're rated north of 100 deg C, IIRC.
I an effort to track down this short I am rechecking every part of the board I have touched for probably the fifth time. I was suspecting a bad new UD8 and UE8 but removing them makes no difference, no raster, no bong, hot chips. This is going to take a while.
is it possible something is shorted under the capacitors? Similar to what I posted here:
I noticed this SE/30 recapping guide specifically calls out "Caution: do not destroy traces near C8 thru C10" - C10 is the one that bit Adrian in video linked above.
I haven't given up. I've pulled off almost all the caps I put on and I'm double checking traces. Definitely have a short between 12v and 5v but not seeing anything obvious. Trying to locate and follow all the 12v line on the board now. Has anyone mapped out all the 12v traces yet? Is it possible the short is inside the board?
I found the short. Basically removed every cap, bodge wire, or anything I had touched. Tested after each removal until I found it. Completely my mistake. Now to rebuild everything again and hope I didn't fry the board.
The only way to real find a short is to use a bench power supply where you can dial in the current max and then use a thermal imaging camera to find the hot spot. You can have a short in the middle of the circuit board between layers and have to Dremel it out.
Welp, as suspected I'm pretty sure I have fried the 68030 on this board at a minimum. I got and assembled one of those SE/30 Peekers and All the data lines are showing as dead. Thankfully this board has a socketed CPU but I have looked and can't find a replacement anywhere (Can I replace the 16MHz CPU with a 30 or 50MHz?). Also since I still don't get a raster or sound likely fried the Video ROM and possibly other chips. Guess this project goes on the shelf until I can find a donor board.
I am still new at repairing retro computers, but if 12V was shorted to 5V like you say, it seems possible every chip on 5V rail is fried not just CPU.
In Adrian's digital basement video below, he accidentally shorted 12V to data line 31 and every chip on data line 31 was fried:
Can you tell us more about the short? where was it located? How did you detect it/fix it?
This is a good point; if youi've shoved 12V up everything that wanted 5V, you may have an ... interesting time trying to get it to work again.
Yup, I watched that video.
Basically I just removed everything i had touched, every cap, every bodge wire, tested after each one, until the short was gone and then reassembled.
Do you know what was the one item/location that fixed the short?
