I've been slowly working on restoring a Power Macintosh 8500/180. It's fully recapped and I just have a ton of broken plastic to deal with. But noticed some strangeness today and was hoping for any insight before digging into it. Note that this machine came with a Newer 500MHz G3 CPU card installed.
Basically if I boot up using the onboard video, the speaker sounds normal. The only issue are some artifacts as I drag windows around but I saw another post that that might be related to the Newer and that installing the accelerator driver for it should resolve that. But the important thing is the speaker sounds normal.
If I install a PCI based ATI Rage 128 (that the machine came with) into any of the PCI slots AND plug in a monitor, the speaker does play all the sounds it's expected to but I'm hearing a lot of noise. All SCSI accesses I can hear through the speaker (sounds like an old physical spinning hard disk), all mouse movements cause noise, etc. If the ATI video card is installed but not plugged into a monitor, speaker sounds normal. It's only when the card is being used and outputting video that I hear static associated with ADB and SCSI traffic. Different VGA cables, different monitors, doesn't change anything so I don't believe it's the VGA cable itself or the monitor it's connected to. I tested the VGA pins on the ATI card for shorts but didn't find any.
