very nice. very very nice.The battery cover won't stay attached to the battery as the clips were broken off. Tried a few things to fix it but none of them worked. Ended up spending time modeling a brand new cover.
First test print was close but I need to fix a few things. Will try a second test print tomorrow.
now if only someone would model the side bumpers that love to harden and crumble to bits.... that would be so awesome. that would be so cool.
Is the PRAM battery the same Panasonic rechargeable thing as in the 1xx series ?
Good to know thank you. I'm gonna order more for my 500 buildYes, same Panasonic VL-2330 rechargeable cell, but different count and configuration.
Duo and 190/5300: 2 of them stacked with three wired plug providing 6V, 3V, ground (the 3V wire goes between the two serially connected cells and only provides power from one of the two cells).
500s: 2 of them side by side with three wired plug providing 6V, 3V, ground (the 3V wire is again between the two serially connected cells and only provides power from one of the two cells).
100s: only 1 cell which is soldered directly onto a PCB.
Now I wish I had taken a photo of the one that showed up on eBay a few months ago...Made a battery contact alignment tool based on the service manual and just inferring what it might look like. Not sure if it actually is to spec with the original tool from Apple but at least on my system, it did allow me to adjust the contacts where it's aligned properly now. Model available via the printables link in my signature.
Yes, think it’s a solid block of aluminum. First AL unibody Mac product!?@Fizzbinn nice!! What's it made out of, metal?
