is there aSetMBarHeight(0);
However, is this still going to work under System 6.0.8 ?
The MSL C 68K library should have it's own@David Cook , I confirm that CodeWarrior likes LMSetMBarHeight(0);
However, is this still going to work under System 6.0.8 ? This is what this app is going to be running on later.
Then, any idea what those are, especially __va() ? This sounds more low level. Maybe in one of the standard THINK C libraries?
snprintf and vsnprintf functions defined in cstdio (#include <stdio.h>) so you can probably surround these by #if !defined(__MWERKS__) to remove these. Do the same in the util.h file.__va() stands for Variable Arguments. If this is from the THINK C code, then it's their pre-VARARGS mechanism for doing it.@David Cook , I confirm that CodeWarrior likes LMSetMBarHeight(0);
It works, but you'd have to replicate it every time you had a dialog that returned OK or ok. One solution, if you're going from THINK C to Metrowerks would be to haveYes, it did it the trickwhile maintaining compatibility with THINK C (which feels redundant, since the original source code is for THINK C 5.0, but oh well) ... Even though the compiler initially was happy and that I have #include <stdio.h> at the top of my main.c file, after fixing other errors, it's complaining that snprintf is an undefined identifier. I'll have to keep it defined in the .c file somehow.
Speaking of which, after a minute scratching my head, I realized that THINK C 5.0 recognizes "OK" as a hit in a Mac dialog window, but CodeWarrior expects "ok" in lowercase. Is there a way to adapt the code so that no matter if the compiler expects "OK" or "ok", both are accepted?
I did it like this and wonder what it's worth to you guys?
I think that would probably work, but it's non-portable. It would be better to use the same method as below. Also, I wouldn't put the return type on a line before the name of a function definition even though that's common practice. The reason is that if you're looking for a function (e.g. using grep) based on its prototype, then conceptually you'd think of all 3 components together: the return type + functionname '(' parameters ')'.I modified 2 places in the whole project, but it's true that a define would maybe be a better approach, although, for some reason, I also came across 1 "ok" which is very strange because then, it means that THINK C 5.0 recognizes both. Either way, it's solved.
I've been trying to fix the variable argument function that CodeWarrior did not like from THINK C 5.0 and I think I got it not too bad. CodeWarrior seems to like that, what do you think? So instead of __va(fmt) I make a new variable (p) and assign it the DATA that is after fmt and that's what I send to vsnprintf() instead of __va() which is undefined in CodeWarrior.
int snprintf(char *s, size_t size, const char *fmt, ...)
va_list argptr;
int retVal;
va_start(argptr, format);
retVal=vsnprintf(s, size, fmt, argptr);
va_end(argptr);
return retVal;
Yes, this is better!In another .c file I also see this, which seems like yet another way of dealing with variable arguments. CodeWarrior does not seem to complain about that way of doing it, so it might be more standard to do it like this with va_start() and va_end() ?
It will be, because FILE is a standard 'C' file type, but the code is trying to use the hidden parameters present in THINK C's FILE type. And also I think it means that f.refnum=-1; means a predefined stream, e.g. error or what THINK C uses for stdout.Anyway, so all that's left to fix is the vsnprintf() function which seemingly wants nothing to do with this FILE typed variable. Every single f.something is undefined. I tried to make a new FILE and it's the same. Any idea? That must be from a THINK C 5.0 library that is not standard or that does not exist in CodeWarrior?
Yes, I have no idea why some programmers do that. Personally, I hate it and I find the code less readable and it uses more lines for no reason which is a pain to scroll through on older Macs. The whole app was programmed like this in 2022 (not by me!).Also, I wouldn't put the return type on a line before the name of a function definition even though that's common practice. The reason is that if you're looking for a function (e.g. using grep) based on its prototype, then conceptually you'd think of all 3 components together: the return type + functionname '(' parameters ')'.
Right, so now I have to find that .c file and try to import it into CodeWarrior. I hope it's not in some proprietary, compressed lib file or I'm screwed.It will be, because FILE is a standard 'C' file type, but the code is trying to use the hidden parameters present in THINK C's FILE type.
I think what you need to do rather is just find out where vsnprintf is normally in MetroWerks. It looks like a standard library routine to me. It's part of <stdio.h>Yes, I have no idea why some programmers do that. Personally, I hate it and I find the code less readable and it uses more lines for no reason which is a pain to scroll through on older Macs. The whole app was programmed like this in 2022 (not by me!).
I found this "file.c" source file in the THINK C 5.0 folder, but I'm not sure yet if it's related or not:
Wait, this looks more promising. I see all the class members that are referenced in the Wiki Reader app in there. That looks like Symantec's own stdio implementation or something? This was in the THINK C 5.0 folder under "C Libraries":
This is interesting because CodeWarrior complains that the FILE struct that it's got is a "_Filet" and not a "__FILE" so clearly, CodeWarrior is using a different stdio.h
