Received a couple weeks ago, and video and rest was working, but no audio. The PRAM battery had not exploded, but all of the electrolytic caps had leaked. The only IC with significant corrosion on the legs was UE8. I recapped with parts from DigiKey, and now I get a loud bong (happy mac) on boot, but the video is now jacked. I have the Console5 analog board recap kit but have not done that work yet.
Was able to remove all of the corrosion, and before starting it looked so bad I thought the legs had rotted completely off. After cleaning multiple times I can see no damage to the legs or pads, but the legs/solder on UE8 is still a little dull. I plan to order UE8 (SN74LS166ADR), UF8/UG8 (SN74LS393DR). See below picture: Can I use the same LS393 for both UF8 and UG8? My ICs are different.
Also, are there any other parts to replace while I'm filling the cart? As you can see the Sony chips have a little blackening on the legs even after cleaning, but nothing was as bad as UG8.
![20250301_203328[1].jpg 20250301_203328[1].jpg](https://68kmla.org/bb/data/attachments/84/84021-f8913c5168603962ace7a6eebe97dd8d.jpg?hash=-JE8UWhgOW)
