I want to ask you another questions. I have obtained a PB 3400 RAM module, which I read works at 3.3V, and I assume that the PB190 RAM works at 5V. The main physical difference is that the connector has been soldered turned 180º, preventing it from being plugged in. I have looked for the reference for the memory chips, and I only found this document where it says that they work at 5V.
UPD4218160G5-60
Could it be that these chips can work interchangeably at 3.3V and 5V? That they have a wide range?
If so, I would try to rotate the connector 180º, and use this 32MB of RAM, because I am not able to find RAM suitable for PB190 at an affordable price. My PB190 has 8MB onboard.
