Did you have to do any configuration in the CUPS admin interface, select the printer, and so on? Or was printing to your LaserWriter plug'n'play once you had installed the pap backend?/usr/lib/cups/backend/pap is what I had to get setup on my v5 to get CUPS working with AppleTalk Printing, the file I'm using is something I found on the Internet and hacked on until it surprisingly worked, at least for what I wanted to do (print to an AppleTalk only LaserWriter from modern machines using the Rpi as a print server). I was hoping the newer Netatalk build would come with that file fixed up.
Did you have to edit cups.conf as well?
What is the exact model of LaserWriter, for our reference?
I'm trying to figure out the best default configuration for netatalk.
