LCIII Video Adapters
dcr
68020
A long time ago, I bought (via eBay, I believe) an assortment of video adapters for converting from the output of a Mac (pre-Intel) video to (mostly) VGA. Of those, I only had one that worked with any sort of reliability (and still a lot of trial and error). The bottom line is that I don't have a reliable adapter, which means if I use one and it doesn't work, I cannot be sure if the issue is with the adapter or the computer.
So, what is/are some good adapters (brands, models, links to eBay/Amazon item) for connecting an LC III to a modern-ish display? The LC III has only the built-in video output. I would prefer to use an HDMI display if there is something available that can convert from Mac video output to HDMI. Alternatively, I do have some displays that take VGA input.
Any recommendations?
Thanks!
Thanks! The Mac Sync-inator seems promising.
Are there no Mac video to HDMI adapters? I suppose I could try a Mac > VGA adapter and then VGA > HDMI adapter but that seems like that might be asking for problems.
HDMI is digital, VGA is analogue. You need a digitiser in the path. Anything that claims to adapt VGAish to HDMI has a digitiser in it, usually a bad one. The scaler I (and a number of other people around here) use with great success is the Extron RGB-HDMI 300 (A), which is relatively available on eBay for reasonable prices if you're a bit patient.
But you'll still need a mac-style d-sub to VGA-style d-sub adapter.
Mac-sync-inator is a great gadget. I have perhaps a half-dozen passive adapters and the sync-inator was the only device that gave me a display from a newly acquired IIci.
This is a bit old, but, speaking from experience, the video output of an LC III can be easily converted to VGA with a non-dipswitched adapter. A dipswitched adapter won't hurt, but they're often a bit more expensive (for obvious reasons).
@lesca: that really depends on the monitor receiving the signal. An old square Dell 17" LCD might be able to handle it, but newer monitors may struggle and will need the Mac Syncinator.
Hi!
I have two of these on their way, also for LC III and 475. I'll let you know if they work when they arrive, but they were recommended by someone who has quite a collection of old Macs and says he uses them on LCs and they work quite well.
Regards,
Miguel Arroz
Hi!
Regards,
Miguel Arroz
I have a Viewsonic-branded one that looks identical to that, and it lets my LC hook up to the mid-2000s Dell LCDs I own (a 19" I got for free at a yard sale 15 years ago and a 15" I got last week at a college clean-out sale) in 640x480. Had to run the auto-detect option on the monitors to sort out some weird vertical banding issue, but now they're flawless and so much bigger yet also lighter than an original screen.
Hi,
So, the good news are, the adapters work! That's an LC 475 feeding a VGA display. Tried both 640x480 and 1024x768.
The bad news is my 475s are in worth shape than I thought. That one form the photo (the "good" one) stopped being good after I tried to boot from BlueSCSI and now it wont boot at all. The other either shows a gray image or the regular image but very washed out. I still have to recap them, but I'm sad… I hope I didn't somehow kill the good LC.
I don't have a keyboard yet so the only way to reset PRAM is by removing the battery and waiting. Let's see if they are in a better mood tomorrow.
Regards,
Miguel Arroz
If they were working at all, the adapter definitely did not contribute to their current problems. I would remove the caps (safely, please don't twist them!), clean the board thoroughly with IPA, and then recap.
