After so many years, I decided to go through a pile (dozen) of SE-30 logic boards that I had bought on CL. I meticulously recap them one by one, and some of them work, but others don't. This particular one gives me the following symptoms:
1) Booth chime is OK. Video is good
2) When no FDD or HDD is connected, I eventually get the Mac with the X icon, and not the usual Mac with the question mark
3) The reset button just turns off and on the video, but does not reboot
4) When I plug in an FDD, the SE30 does not "see it"
5) When I plug in an HDD, it starts booting on it, but eventually crashes with various error codes (depending on the HDD I use)
The LB is surprisingly clean, and there are no obvious issues with missing traces etc.. Do you guys have any clue on the issue ?
Thanks in advance.
Thanks in advance.
