TashRouter is now working over AppleTalk, the AARP lookup/reply shows that. LToUDP traffic shouldn't be going over the tap interface at all. On Linux, TashRouter's LToUDP always seems to correctly select the main NIC and send out packets in my setup.
I do have the problem with Minivmac on Windows though. It always seems to pick the wrong interface on first run and since there is no network configuration option, I force it to the right adapter by temporarily disabling other interfaces before launch.
If TashRouter is broadcasting over the main NIC, a Minivmac client should see AppleTalk zones at a minimum.
