0.0 whenever netatalk replies to NBP Requests. These packets will crash TashRouter and leave it running in an unrecoverable state since it can't currently handle packets when an origin of 0.0. I have submitted a pull request that fixes this here: https://github.com/lampmerchant/tashrouter/pull/90.0 is not valid on an extended network.Have you escalated this to the kernel devs?Note for those running Linux kernel 6.9 or newer. It appears that a regression has been introduced that NBPReply packets are being duplicated and sent out with a source address of0.0whenever netatalk replies to NBP Requests. These packets will crash TashRouter and leave it running in an unrecoverable state since it can't currently handle packets when an origin of0.0. I have submitted a pull request that fixes this here: https://github.com/lampmerchant/tashrouter/pull/9
The patch simply drops these packets since an address of0.0is not valid on an extended network.
router = Router('router', ports=(
LtoudpPort(seed_network=1, seed_zone_name=b'LToUDP Network'),
# TapPort(tap_name='tap0', hw_addr=b'\xF2\x0B\xA4\xE1\xF9\x2E'),
# TapPort(tap_name='tap0', hw_addr=b'\xF2\x0B\xA4\xE1\xF9\x2E', seed_network_min=3, seed_network_max=5, seed_zone_names=[b'EtherTalk Network']),
TapPort(tap_name='vether0', hw_addr=b'\xF2\x0B\xA4\x41\x01\xC4', seed_network_min=3, seed_network_max=5, seed_zone_names=[b'EtherTalk Network']),
arm64$ ifconfig -a
vioif0: flags=0x8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ec_capabilities=0x1<VLAN_MTU>
ec_enabled=0x1<VLAN_MTU>
address: 52:54:00:f0:0d:01
status: active
atalk 65280.111 phase 2 range 1 - 65534 broadcast 65280.255
inet6 fe80::5054:ff:fef0:d01%vioif0/64 flags 0 scopeid 0x1
inet6 fd7c:c94b:1296:3149:d476:7e:b20c:e5b/64 flags 0x40<AUTOCONF>
inet 192.168.11.248/24 broadcast 192.168.11.255 flags 0
lo0: flags=0x8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 33624
status: active
atalk 0.0 phase 2
inet6 ::1/128 flags 0x20<NODAD>
inet6 fe80::1%lo0/64 flags 0 scopeid 0x2
inet 127.0.0.1/8 flags 0
tap0: flags=0x8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ec_capabilities=0x5<VLAN_MTU,JUMBO_MTU>
ec_enabled=0
address: f2:0b:a4:e1:f9:2e
status: no carrier
inet6 fe80::f00b:a4ff:fee1:f92e%tap0/64 flags 0x8<DETACHED> scopeid 0x3
bridge0: flags=0x41<UP,RUNNING> mtu 1500
status: active
tun0: flags=0x10<POINTOPOINT> mtu 1500
status: down
vether0: flags=0x8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
address: f2:0b:a4:41:01:c4
status: active
inet6 fe80::f00b:a4ff:fe41:1c4%vether0/64 flags 0 scopeid 0x6
In NetBSD 10.0 and later, it will become necessary to use vether instead of tap as a bridge endpoint. vether is unavailable in previous releases.
tash0. In atalkd.conf, I have two lines, one for the host NIC (eth0) and one for the tap interface (tash0).vioif0 -seed -phase 2 -net 2 -addr 2.222 -zone "EtherTalk Network"
tap0 -seed -phase 2 -net 3 -addr 3.141 -zone "EtherTalk Network"
Dec 16 19:49:39 arm64 atalkd[1466]: zip_getnetinfo for vioif0
Dec 16 19:50:10 arm64 atalkd[1466]: as_timer configured vioif0 phase 2 from seed
Dec 16 19:50:10 arm64 atalkd[1466]: as_timer: can't route 2.222 to loop: File exists
Dec 16 19:50:10 arm64 atalkd[1466]: difaddr(0.0): Can't assign requested address
2024-12-16 21:42:08,239 DEBUG: frame in LToUDP 254 32 type 01 b'\x00\x1a\x02\xfe\x02\x11\r\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-16 21:42:08,241 DEBUG: in to 1.254 LToUDP 0 0.254 0.32 2 254 2 b'\x11\r\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-16 21:42:08,242 DEBUG: out to LToUDP Network LToUDP 0 0.255 1.254 2 2 2 b'!\r\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-16 21:42:08,242 DEBUG: frame out LToUDP 255 254 type 01 b'\x00\x1a\x02\x02\x02!\r\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-16 21:42:09,775 DEBUG: out broadcast LToUDP 0 0.255 1.254 1 1 1 b'\x00\x01\x08\xfe\x00\x00\x82\x00\x03\x80\x00\x05\x82'
2024-12-16 21:42:09,777 DEBUG: frame out LToUDP 255 254 type 01 b'\x00\x12\x01\x01\x01\x00\x01\x08\xfe\x00\x00\x82\x00\x03\x80\x00\x05\x82'
2024-12-16 21:42:09,777 DEBUG: out broadcast tap0 0 0.255 3.141 1 1 1 b'\x00\x03\x08\x8d\x00\x03\x80\x00\x05\x82\x00\x01\x00'
2024-12-16 21:42:09,777 DEBUG: frame out tap0 090007FFFFFF F20BA4583A2A b'\xaa\xaa\x03\x08\x00\x07\x80\x9b\x00\x1a\xb4\xf6\x00\x00\x00\x03\xff\x8d\x01\x01\x01\x00\x03\x08\x8d\x00\x03\x80\x00\x05\x82\x00\x01\x00'
Actually, it may not be the wrong thing to do... memory's a little hazy on the details but I think the way Linux works with tun/tap is that you open /dev/net/tun and then use TUNSETIFF to select the specific device to use - and pass the IFF_NO_PI flag to disable an extra frame header of some kind. If BSD has you open the device directly and just provides unadorned raw frames by default, what you describe may be the right approach. Might be sensible to add support for that to TapPort in the codebase since NetBSD's support for AppleTalk means a lot of potential TashRouter users will be using it...But I suspect commenting out the ioctl is the wrong thing to do.
Set TashRouter's seed_network_max=3. The seed configuration between the two routers has to match (network range 3-3, zone name "EtherTalk Network"). Also, you likely have to create the tap interface as root and run TashRouter as root. This was the case under Linux.I had tried your approach (putting both the NIC interface and the tap interface in atalkd.conf, as well as @finkmac 's approach of creating a bridge interface and only including that interface in atalkd.conf. Yours got me further down the path, in that I could see activity on both the LToUDP and tap0 interfaces, but neither are sending packets back for incoming LToUDP queries.
No response ever comes back with the AFP server name. Presumably that's expected because with an empty atalkd.conf, the server is running in vioif0 and there is no connection with the tap0 interface. The light hasn't come on for me yet.
tap0 on the second line, and let TashRouter be the only seed router.Thanks, that makes sense and got me past the "can't assign requested address" errors.Set TashRouter's seed_network_max=3. The seed configuration between the two routers has to match (network range 3-3, zone name "EtherTalk Network").
Yes, I'm creating the tap interface as root and running TashRouter as root.Also, you likely have to create the tap interface as root and run TashRouter as root. This was the case under Linux.
Tried this. Initially atalkd wasn't happy with the single interface specification and kept rewriting my atalkd.conf file as follows:Optionally, you can setup atalkd with justtap0on the second line, and let TashRouter be the only seed router.
vioif0 -phase2 -net 1-65534 -addr 65280.183
tap0 -router -phase 2 -net 3 -addr 3.141 -zone "EtherTalk Network"
TapPort(tap_name='tap0', hw_addr=b'\xF2\x0B\xA4\x58\x3A\x2A', seed_network_min=3, seed_network_max=3, seed_zone_names=[b'EtherTalk Network']),
Dec 17 13:41:34 arm64 afpd[8910]: Puppet Head:AFPServer@* started on 3.141:128 (4.0.9dev)
Dec 17 13:41:34 arm64 afpd[8910]: Netatalk AFP/TCP listening on 192.168.11.248:548
arm64# nbplkup
Puppet Head:AFPServer 3.141:128
arm64:netatalk 3.141:4
arm64:Workstation 3.141:4
2024-12-17 13:58:30,891 DEBUG: frame in LToUDP 254 32 type 01 b'\x00\x1a\x02\xfe\x02\x11<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-17 13:58:30,892 DEBUG: in to 1.254 LToUDP 0 0.254 0.32 2 254 2 b'\x11<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-17 13:58:30,893 DEBUG: out to EtherTalk Network tap0 0 0.255 3.48 2 2 2 b'!<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-17 13:58:30,894 DEBUG: frame out tap0 0900070000A6 F20BA4583A2A b'\xaa\xaa\x03\x08\x00\x07\x80\x9b\x00"k\xab\x00\x00\x00\x03\xff0\x02\x02\x02!<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-17 13:58:30,894 DEBUG: out to EtherTalk Network LToUDP 0 0.255 1.254 2 2 2 b'!<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
2024-12-17 13:58:30,894 DEBUG: frame out LToUDP 255 254 type 01 b'\x00\x1a\x02\x02\x02!<\x00\x01 \xfe\x00\x01=\tAFPServer\x01*'
(sequence repeats until Chooser is closed)
Current atalkd.conf:Something isn't working still. Maybe TashRouter still needs tweaking to work with a tap interface on NetBSD. If everything was working properly, atalkd should have sent a ZIP GetNetInfo packet over the tap interface, and TashRouter would have responded with the setup information. Running something like tcpdump or equivalent should show periodic RTMP packets coming from both atalkd and TashRouter advertising their routes.
tap0 -router -phase 2 -net 3 -addr 3.17 -zone "EtherTalk Network"
Dec 17 17:20:37 arm64 atalkd[10038]: Set syslog logging to level: debug
Dec 17 17:20:37 arm64 atalkd[10038]: restart (4.0.9dev)
Dec 17 17:20:39 arm64 atalkd[10038]: zip_getnetinfo for tap0
Dec 17 17:21:10 arm64 atalkd[10038]: as_timer configured tap0 phase 2 from seed
Dec 17 17:21:10 arm64 atalkd[10038]: ready 0/0/0
17:20:36.277053 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
17:20:37.549041 aarp probe 3.17 tell 3.17
17:20:37.763866 aarp probe 3.17 tell 3.17
17:20:37.979615 aarp probe 3.17 tell 3.17
17:20:38.193062 aarp probe 3.17 tell 3.17
17:20:38.411792 aarp probe 3.17 tell 3.17
17:20:38.627214 aarp probe 3.17 tell 3.17
17:20:38.839966 aarp probe 3.17 tell 3.17
17:20:39.053254 aarp probe 3.17 tell 3.17
17:20:39.268254 aarp probe 3.17 tell 3.17
17:20:39.486144 aarp probe 3.17 tell 3.17
17:20:39.706853 AT 3.17.zip > 0.zip: at-#6 7
17:20:47.111155 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
17:20:50.559316 AT 3.17.zip > 0.zip: at-#6 7
17:20:57.963401 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
17:21:00.485033 AT 3.17.zip > 0.zip: at-#6 7
17:21:08.799109 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
17:21:10.488840 AT 3.17.rtmp > 0.rtmp: at-rtmp 16
17:21:10.513663 AT 3.17.nis > 0.nis: nbp-lkup 1: "arm64:Workstation@EtherTalk Network" [addr=3.17.129]
21:20:22.418742 aarp probe 6502.183 tell 6502.183 <-- TashRouter AARP Probe
21:20:22.622576 aarp probe 6502.183 tell 6502.183
21:20:22.823363 aarp probe 6502.183 tell 6502.183
21:20:23.030881 aarp probe 6502.183 tell 6502.183
21:20:23.249912 aarp probe 6502.183 tell 6502.183
21:20:42.228050 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13 <-- TashRouter RTMP Broadcast
21:20:49.534324 aarp probe 6502.16 tell 6502.16 <--atalkd AARP Probe
21:20:49.644321 aarp probe 6502.16 tell 6502.16
21:20:49.754553 aarp probe 6502.16 tell 6502.16
21:20:49.863303 aarp probe 6502.16 tell 6502.16
21:20:49.974067 aarp probe 6502.16 tell 6502.16
21:20:50.081714 aarp probe 6502.16 tell 6502.16
21:20:50.206146 aarp probe 6502.16 tell 6502.16
21:20:50.322874 aarp probe 6502.16 tell 6502.16
21:20:50.432162 aarp probe 6502.16 tell 6502.16
21:20:50.537790 aarp probe 6502.16 tell 6502.16
21:20:50.674464 AT 6502.16.zip > 0.zip: at-#6 7 <-- atalkd broadcasts ZIP GetNetInfo
21:20:50.674743 AT 6502.183.zip > 6502.16.zip: at-#6 23 <-- TashRouter ZIP GNI Reply
21:20:52.769330 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:00.694437 aarp who-has 6502.183 tell 6502.16 <-- atalkd AARP probe for TashRouter's MAC
21:21:00.694542 aarp reply 6502.183 is-at aa:bb:cc:dd:11:22 (oui Unknown) <-- AARP Reply
21:21:00.694545 AT 6502.16.zip > 6502.183.zip: at-#6 6 <-- Zone list queries between routers
21:21:00.694803 AT 6502.183.zip > 6502.16.zip: at-#6 13<-|
21:21:00.694816 AT 6502.183.zip > 6502.16.zip: at-#6 13<-|
21:21:02.775702 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:12.778709 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:21.480525 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:Workstation@A2SERVER" [addr=1.232.129]
21:21:21.480536 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (34)
21:21:22.803635 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:24.186877 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:Workstation@A2SERVER" [addr=1.232.129]
21:21:24.186890 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (34)
21:21:27.039251 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:Workstation@A2SERVER" [addr=1.232.129]
21:21:27.039262 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (34)
21:21:30.428495 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:netatalk@A2SERVER" [addr=1.232.129]
21:21:30.428505 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (31)
21:21:30.820757 AT 6502.16.rtmp > 0.rtmp: at-rtmp 16 <-- atalkd RTMP broadcast
21:21:32.702748 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:netatalk@A2SERVER" [addr=1.232.129]
21:21:32.702759 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (31)
21:21:32.822130 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:35.927102 AT 6502.16.nis > 0.nis: nbp-lkup 1: "debtest:netatalk@A2SERVER" [addr=1.232.129]
21:21:35.927113 AT 6502.16.nis > 5.0.nis: nbp-0x41 1 (31)
21:21:39.936714 AT 6502.183.zip > 6502.16.zip: at-#6 4
21:21:39.936742 AT 6502.16.zip > 6502.183.zip: at-#6 13
21:21:40.682334 AT 6502.16.rtmp > 0.rtmp: at-rtmp 16 <--- Everything is configured, both routers broadcast periodic RTMP packets when idle.
21:21:42.831792 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:21:52.138134 AT 6502.16.rtmp > 0.rtmp: at-rtmp 16
21:21:52.843334 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:22:00.791387 AT 6502.16.rtmp > 0.rtmp: at-rtmp 16
21:22:02.852991 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
21:22:11.672702 AT 6502.16.rtmp > 0.rtmp: at-rtmp 16
21:22:12.856078 AT 6502.183.rtmp > 0.rtmp: at-rtmp 13
22:08:36.987646 AT 3.17.rtmp > 0.rtmp: at-rtmp 16
22:08:41.748276 IP dhcp248.home.lan > 239.192.76.84: igmp v2 report 239.192.76.84
22:08:42.025056 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:42.309347 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:42.593435 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:42.805688 IP dhcp248.home.lan > 239.192.76.84: igmp v2 report 239.192.76.84
22:08:42.870485 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:43.148159 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:43.429073 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:43.711635 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:43.993659 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 7
22:08:46.922837 AT 3.17.rtmp > 0.rtmp: at-rtmp 16
22:08:52.565172 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
22:08:56.951258 AT 3.17.rtmp > 0.rtmp: at-rtmp 16
22:09:03.386542 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
22:09:06.955787 AT 3.17.rtmp > 0.rtmp: at-rtmp 16
22:09:14.244027 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
diff --git a/tashrouter/port/ethertalk/tap.py b/tashrouter/port/ethertalk/tap.py
index eb0fba6..2eb8f86 100755
--- a/tashrouter/port/ethertalk/tap.py
+++ b/tashrouter/port/ethertalk/tap.py
@@ -13,6 +13,9 @@ from . import EtherTalkPort
class TapPort(EtherTalkPort):
'''Port driver for EtherTalk using TUN/TAP.'''
+ TUNTAP_LINUX = 0
+ TUNTAP_NETBSD = 1
SELECT_TIMEOUT = 0.25 # seconds
TUNSETIFF = 0x400454CA
@@ -40,8 +43,11 @@ class TapPort(EtherTalkPort):
__repr__ = short_str
def start(self, router):
- self._fp = os.open('/dev/net/tun', os.O_RDWR)
- ioctl(self._fp, self.TUNSETIFF, struct.pack('16sH22x', self._tap_name.encode('ascii') or b'', self.IFF_TAP | self.IFF_NO_PI))
+ if self.TUNTAP_LINUX == 1:
+ self._fp = os.open('/dev/net/tun', os.O_RDWR)
+ ioctl(self._fp, self.TUNSETIFF, struct.pack('16sH22x', self._tap_name.encode('ascii') or b'', self.IFF_TAP | self.IFF_NO_PI))
+ elif self.TUNTAP_NETBSD == 1:
+ self._fp = os.open('/dev/' + self._tap_name, os.O_RDWR)
super().start(router)
self._reader_thread = Thread(target=self._reader_run)
self._reader_thread.start()
Clarification: it isn't actually sending replies. It's now broadcasting RTMP packets from a distinct node. Still not seeing replies for name lookups.OK, a light just went on for me. The intent of TashRouter's TapPort class is to open a tap device, not a tun device. I was confused because the Linux code opens '/dev/net/tun', but the ioctl actually sets IFF_TAP to indicate a tap device (and IFF_NO_PI to indicate no packet info). Changing the code to directly open the tap device on NetBSD causes TashRouter to get registered on that device and send AppleTalk replies!
00:48:15.593462 IP dhcp248.home.lan.abr-api > 239.192.76.84.abr-api: UDP, length 25
00:48:15.595532 AT 3.147.rtmp > 0.rtmp: at-rtmp 25 <-- this is TashRouter
00:48:15.595539 AT 3.147.rtmp > 0.rtmp: at-rtmp 25
00:48:16.964990 aarp who-has 3.147 tell 3.17
00:48:16.967535 AT 3.17.rtmp > 0.rtmp: at-rtmp 16 <-- this is atalkd
00:48:16.968163 aarp reply 3.147 is-at f2:0b:a4:58:3a:2a (oui Unknown)
00:48:16.968168 aarp reply 3.147 is-at f2:0b:a4:58:3a:2a (oui Unknown)
