Have a 9GB scsi HDD I’m trying to use with a IIsi. I can boot from a CD image on a ZuluSCSI to format and install an OS.
When I initialize the drive I get a prompt about volume size, so I create a 1GB volume. It mounts, I install an OS, and then… nothing. It won’t boot from the volume and if I reboot from the ZuluSCSI and try to mount the volume with disk utility, I get an error saying I need a 68040 or PPC to use the “large volume.”
I’ve done this same thing twice now with the same issue. (Tried installing 7.1 and 7.5.)
Do I need a 68040 or PPC to support drives (not just volumes) over a certain size? All I can find online are references to the maximum volume size (2GB for 7.1, 4GB for 7.5, etc.)
