As per title, nubus slot A (the one with the inline DAV slot) works superficially, but attempting to use functions of a card installed in that slot freezes the system in pretty short order.
Tested so far with three scsi cards (SEII, SEIV, Jackhammer) as those are what I have on hand. All exhibit similar behavour, they work normally, but very unstable. Failure mode is a soft system freeze that can be rebooted with command-ctrl-power.
All three cards work perfectly fine in slot B.
Anyone know of any common faults that might cause these symptoms?
