So I’ve got this SuperMac Thunder/24 which seems to almost work properly. It installs, boots, throws a video signal, etc.
I downloaded the drivers from the Macintosh Garden and the Control Panel works with all the extra widgets and stuff.
The only issue is that if the cursor goes onto the screen driven by the card, it freezes. The mouse button works but it stops tracking mouse motion. If I boot with the card as the primary display the cursor never moves. (Just is stuck in its home position over the Apple menu.)
I’ve tried with acceleration and the extra pointer options/snap on and off, same result.
Is this a known problem with these cards? I’m using 7.6.1 on a Quadra.
Are there any good resources online for these cards? They seem popular (read: expensive) but I can’t find much outside of a few brief compatibility references on sites like LowendMac.
