Hi all!
An acquaintance of my wife reached out this weekend to say that they were at a yard sale and had spotted "an old Mac for $20 - do you want it?" Obviously we said YES, and it turned out to be a lovely Mac Plus, complete with keyboard, mouse, and an ImageWriter II. Not bad!
The Mac itself is in good condition overall, with no obvious signs of physical or water damage, and the old battery had miraculously not leaked. Unfortunately, when I powered it on, the display just rotates through a variety of garbage patterns, and there's never a chime:
It's safe to assume that this machine is due for a fresh set of capacitors, but I don't want to assume that bad caps are also the cause of this odd visual behavior. Any suggestions on where I should start? I haven't opened the machine up to take a look inside yet, so I'll definitely be giving it a careful inspection, including making sure that the RAM SIM's are seated properly.
I should also note that the mouse cable is cut in half. The internal wires appear to be color-coded, so I'm optimistic that I can rejoin them and use the mouse, but if not: anyone know of a good option for a replacement mouse cable?
Thanks for any suggestions on troubleshooting this beautiful Mac Plus!
Huxley
Huxley
