Mac isii RAM issue
I have a Mac isii with 4 1Mb SIMMs, but it's struggling to run applications that require 2000K RAM. Anyone know why "system software" is eating so much of it? Just bad chips? I've tried cleaning and reseating the SIMMs but I'm honestly thinking of just buying some new ones to see if they'll work. Figured I'd see if anyone else has some input before spending the money on only a potential fix.
This is almost certainly a software issue not a hardware issue.
What does the system's memory footprint look like if you boot with extensions off? (Hold the shift key while booting)
After confirming that 32 bit addressing is turn on, perhaps use virtual memory or buy bigger simms. I have 4 each 2 mb simms if you want them.
No need for 32 bit addressing for 4 meg of RAM - only if you want more than 8 IIRC?
True, but in 24 bit mode the operating system takes most of the unallocated RAM usually leaving hardly anything available for applications.
Based on the photo posted it shows that there is available RAM so I assume that 32 bit is already on.
This is only the case if you have more RAM installed than the 24-bit addressing threshold. Under those circumstances, the extra RAM is shown as allocated to the OS (although note that it isn't actually allocated to the OS in any meaningful way). Under the threshold, 32 bit addressing has minimal to no effect.
It was an extensions issue, thanks all for all the input. I bought the computer from a university surplus so there were all kinds of now unnecessary networking/file management extensions that I really didn't think would eat up as much ram as they did.
