I want to install Python on my eMac and some packages like NumPy, Matplotlib, etc.
Installing the Python package was easy. I downloaded v3.5.4 from python.org. With some help from Google, I was able to get pip installed. I have pip and pip3 running, it seems.
However, I cannot install any packages on the machine. My attempts to install NumPy bonk out with error code 1. The process seemingly cannot get the underlying libraries NumPy depends on. I think it’s because of a security certificate issue.
Is there any way I can make this work or am I out of luck here?
Thanks!
Thanks!
