Hi all,
Can someone point me to the VRAM on this 3500 board? On the Mack of the board there are four
V53C16258LT50 chips and the datasheet I found for these says they are 256K X 16 so that would mean 1MB. These are also sitting next to the vga connector and video display connector so I’m suspecting this is the VRAM
Do I need to be concerned with the LT50 if I can source these ram chips out? I’m having no luck finding LT50 but I am finding HK50.
Also on the back are two KM416V4104AS and the datasheet I found says those are 4MB so that would be 8MB total. Assuming this is the standard ram.
V53C16258 Datasheet, PDF
V53C16258 Datasheet. Part #: V53C16258H. Datasheet: 556Kb/20P. Manufacturer: Mosel Vitelic, Corp. Description: HIGH PERFORMANCE 256K X 16 EDO PAGE MODE CMOS DYNAMIC RAM OPTIONAL SELF REFRESH. 45 Results. Part #: V53C16258HK25. Datasheet: 556Kb/20P. Manufacturer: Mosel Vitelic, Corp.
www.alldatasheet.com
KM416V4104 Datasheet, PDF
KM416V4104 Datasheet. Part #: KM416V4104B. Datasheet: 806Kb/36P. Manufacturer: Samsung semiconductor. Description: 4M x 16bit CMOS Dynamic RAM with Extended Data Out. 3 Results. Part #: KM416V4104C. Datasheet: 808Kb/36P. Manufacturer: Samsung semiconductor.
