It's not exactly a museum piece. I'm fine with bodging in something else. But I still want to dig deeper first. The voltage on the 0120 VRTC pin going back up to VBATT while the CUDA is probably resetting during / after pressing the CUDA button really makes me uneasy. I just can't see what could be causing that behaviour. My gut says that an output from the CUDA is shorted to ground which could explain why the voltage goes to about VBATT during reset and current drops to nearly 0. If that's the case then I need to check a bit more, and depending on the result possibly give up.Nope, that's a custom part. 0120 is shorthand for 343S0120. You could theoretically replace it with some other battery voltage monitor IC, but that would need a bodge.
