Should not be. PDS cards have to generate their own timing and address decoding. So unless the SRAM is at a gross incompatible speed, it should be fine.
and he probably didnt mean PDS. he meant the RAM slot. they are different between the two.
Yes, I meant RAM slot. PDS RAM cards are quite different, and my understanding is that some degree of interchangeability exists such that a single PDS RAM card should work in either Portable model.
All my post was dictating was why 5120 and 5126 RAM cards are NOT interchangeable in the RAM slot. PSRAM requires a refresh signal which isnt present on the 5120.
I had heard that the PDS RAM card can use M5120 and M5126. But my PDS RAM card can use only M5120 and I don't use for M5126. I was surprised to know that.
