Mac plus question..
Sorry if this is a dumb question, but there are different variations of the mac plus correct? The original and then the 1mb version?? Are the logic boards different to? or the same. I dont want to rip them apart to check.. feeling lazy lol.. i
The first mac plus had 1MB RAM. The case had the same color like the 128k or the 512k. Later there was a case with platinum color. The main difference to the 512k was a SCSI port and a larger ROM. AFAIK there were two or three different ROM versions.
Main difference is the color, former ones were the same as the 128 and 512 units. Late units were white or rather platinum.
Logic boards were all 1Mb with a maximum upgrade at 4Mb, Roms can be slighly different… but not much.
Not a huge evolution.
Ok, thanks for clarifying!
