I've been slowly discovering a lot about the G4 Cube which in my opinion is one of the best looking Mac's Apple ever made. After looking for one for a while my good friend @Jockelill gave me a great deal on one and I've been loving the device a whole lot since receiving it. I've slowly discovered some of its strange development choices and have been questioning one choice more than any, the removal of an internal speaker? I know this has been brought up before but the answer I don't believe has ever been found. If you ever look at the internals of a G4 Cube most of us have seen that there is a white connector and an empty space for a G4 speaker (photos below) the same speaker found on the tower models. Now if you put two and two together you'll see that the speaker not only fits perfectly but also appears as though it would connect simply to that white connector and by slapping the Cube back together you'd expect sound or something. However, one would find this simply doesn't happen. Obviously this was planned but ultimately removed.
Proof of the original idea for internal speakers I believe can be further backed by the serial number labels of some early G4 Cubes that give away this with the inclusion of the text "SPEAKERS" (I borrowed this photo below from an Ebay listing HERE in case you're interested in this listing, not that this means it's special there are many other examples like this).
Now here's where it gets even more interesting. I happen to know someone with a few prototype G4 Cube's that have an internal speaker which as it turns out is the same as a tower G4's internal speaker. However when I asked if this individual's Special G4 Cube's chimed on boot up or ever output sound I was surprised to hear the answer was "No" and even on an example with totally preproduction ROM's the answer was the same. So I decided to do a little more research. If you look on a G4 Cube's logic board you will see a chip labeled "MICRONAS DAC3550A" the data sheet can be found HERE. This chip is what controls audio for the G4 Cube and you'll be surprised (or not) to learn that upon pulling up the data sheet there is an internal amplifier and pins for audio out. Albeit it nothing loud there still should be sound.
Pins 5 and 7 are most important here. The chip should be able to output any sound from the machine on these pins if a speaker is hard wired in and that's exactly what I did. However I discovered I still received no sound out. So at this point I'm questioning if maybe the audio output is software controlled in a way that the OS will only output sound through USB and the infamous Hardon-Kardon speakers. I haven't tried installing Linux or Windows on these (nor am I going to) so I can't confirm if maybe hardwiring in a speaker the same way would work. But if anyone has any ideas or wants to give it a shot and share, please by all means do. I would love to have an internal speaker in this machine without any crazy mods or wires going in and out of the back. But as it stands these are my findings.
