Working on my SE FDHD.
Recaps went well. Tested voltages. Everything looked great. Put it back together.....
FORGOT TO CONNECT THE ANODE CAP!!! (Yes, Dumb, dumb, dumb...)
Anyhow, it ran for about 15 seconds before I realized the issue so I powered down and connected the anode cap.
The result is it works fine except I am have a very minor scan line coming down the CRT at a regular interval just like if you were recording it on a video but much, much less obvious. It does bug me enough to ask the question.
Have I taken out a component or worse, damaged the transformer by running it without the anode cap connected? Could this be caused by the recaps in some way. All the caps are the right specs.
Thanks for any guidance.
