Consider upgrading the ROM, you can find kits on eBay and elsewhere. You'll need to upgrade beyond ROM 255 in order to use Smartport hard disk images like Total Replay.
Yes I do plan on doing this at some point! However it looks like that's about $80 and requires some soldering (which I am very bad at), so I'll have to build up the courage for that
I have been using ADTPro, it was honestly surprising how easy it was to get working! I have about 10 floppies that I've been swapping around with various software.
Dumb question about 5.25" floppies - if they box says they're "double sided", should they just work if I flip them over? Or do I have to cut the "notch" on the other side?
IIRC it’s one trace to cut, and one bridge to solder. The soldering is the easy part! It does not require any precision. Cutting on the other hand: you don’t want to slip! But it’s not in any way delicate work.
And don’t pay 80 dollars just for one programmed ROM chip. It must be more like $20. I bought mine here:
Les meilleures offres pour Apple IIc / IIc+ puce ROM 04 / ROM 4X / ROM 5X sont sur eBay ✓ Comparez les prix et les spécificités des produits neufs et d'occasion ✓ Pleins d'articles en livraison gratuite!
I have plenty of 25C256/512 chips, I can burn the chip(s) for ROM4X or ROM5X for you for $10 each plus US postage (usually about $4). A little more expensive if you want a non-windowed SST SF EEPROM that can be rewritten without a UV eraser. If you don't plan on reprogramming it, a normal EPROM is fine.
There's no "serious" soldering involved. See my walk-through of my own IIc's ROM upgrade here: https://www.bigmessowires.com/2015/05/29/apple-iic-rom-upgrade/ Cut one trace on the PCB, and add one solder blob to a giant solder bridge on the PCB. The solder bridge is huge and impossible to mess up.
You literally flip them over and notch it. Or you can install a write-protect override switch onto your floppy drive, then you don't have to bother with notching. Some disks come pre-notched and pack of stickers.
is there anyone near you that can help? Someone with a desoldering gun and an EEPROM writer wouldn't be too bothered about helping. It shouldn't take more than a few minutes. Take longer to drink their coffee.
Edit - from other responses, it sounds like you don't even need to desolder the chip, so you only need to make them half a cup of coffee
