I have a total of 4 boards that I want to see how far they can go with bus speed. So far, I have only tested one (a 7300/200). I will test the 8600/250 next, and once I do something about a PSU, I can test the 7600 and 9500.
Currently still working with the 7300. All memory slots are filled, and memory is interleaved. All RAM is 60ns EDO RAM. CPU is a ZIF carrier with under-clocked G4 and oversized heatsink. Here are my observations so far:
60 MHz - No boot
58 MHz - Boot not guaranteed
57 MHz - Always boots, but usually get data read errors using Stuffit Expander
55.6 MHz - Seemed fine until I went to install Mac OS 9 (from one ZuluSCSI partition to another). I got an error 'problems were encountered reading the source file "Installation Tome". Installation cannot continue'
54 MHz - Same as above
53 MHz - Made it further into the install, but got a different data read error
52 MHz - Works great
So here are my questions:
1) Are these valid correlations I have made?
2) If so, is there a memory tester for OS 9 that works as well as running the OS installer?
3) Should I worry about individual 60ns EDO modules not being able to handle up to 60MHz bus speeds?
4) Should I worry about PCI cards or SCSI devices restricting bus speed?
I might try un-interleaving the RAM, but I really don't want to go as far as testing individual memory modules unless I am convinced that they are not keeping up with whatever they are spec'd to.
60 MHz - No boot
