I purchased two of these boards, however I do have a little gripe about the layout, please don’t flame me….
so look at the images, I noted that this seems to be a trend about most makers, the circuit is fantastic, the design also etc etc…. But, everyone assumed these will live by themselves, as if the whole point is to make them central to the machine the user will employ them in. however, and the Zuluscsi is better than most, these things replace hard drives, in places where hard drives normally are housed, and powered with either term power or the molex (not berg) ps connector….
Thanks for the contribution, and the feedback. The community would definitely benefit from you sharing the Gerbers. It should be noted that both the full-size ZuluSCSI (and SCSI2SD V5.1/V5.2, SCSI2SD V6) all are designed to with the standard bottom-facing 2.5" mounting holes, as specified in the SFF-8201 specification, on pages 8 and 9. This allows you to use many, many off-the-shelf 2.5" to 3.5" mounting brackets.
In almost every case, with almost every Mac, no external power is necessary, by design, as nearly every mac supplies SCSI termination power both internally and externally, as do most other non-Macintosh SCSI controllers.
There's a reason why we sell ZuluSCSI without the Berg connector by default; It isn't needed in most scenarios, and it adds needlessly to the cost of the board. This is precisely why it's optional.
I think you mean Berg (floppy-style), since there's no such thing as aso why not make a pcb that replicates the hd layout? In this case, I built an adapter (actually jlcpcb made it for 2$) to mount the zuluscsi to a standard Mac sled - the Berger
When assembled, the IDC50 connector _is_ at the very edge of the board. I assume you're referring to the location of the footprint itself, relative to the edge of the board. Such a change would make it significantly more difficult to correctly assemble the IDC50 connector and have it be at a perfect right angle. Such a change would increase the difficulty for most people assembling the board. Your mounting solution solves your concern.connector is thankfully on the correct side (vs someone else’s scsi to sd adapter) , but the connector should be at the very edge of the pcb and not inside by 8mm - so that tight fitting cables should unnaturally bend to reach the connector, as is the case for the Color Classic.
I don't see it as a rant, but I do see it as somewhat of an "only my specific use cases matter" critique. When designing a product, there are many other factors to consider, when designing a product. Manufacturability and cost considerations are equally, if not more, important.I apologize for the rant, but when something is made so well even a little cut corner becomes a sore thumb. Thank you for the Zuluscsi, I just love it!
