Following on from our full-sized ZuluSCSI RP2040, which we released back in November of last year (2022), we've got another entrant to the ZuluSCSI family, available for purchase today in kit form, starting at a mere $42, from https://store.rabbitholecomputing.com/ZuluSCSI-Compact-Homebrew-p/zuluscsi-compact-homebrew-kit.htm
ZuluSCSI Compact Homebrew is only available as a DIY kit, comprised of easy-to-solder through-hole components. Heat up your soldering iron and solder on the 50 pin internal SCSI (IDC) connector, capacitors, pin headers, and the berg/LP4 power connector, and you're ready to go. All surface-mount components are factory-assembled, and the SCSI interface on the board has been tested.
SCSI termination is controlled via DIP switch, as is Initiator mode.
Initiator mode allows ZuluSCSI Compact Homebrew to function as a SCSI controller, letting you attach almost any hard drive, CD-ROM drive, Zip/Jaz drive, magneto-optical drive, and make byte-for-byte copies of the contents of them. The firmware polls the SCSI bus for all available SCSI IDs, and, if found, writes them directly to an image file on the SD card.
ZuluSCSI Compact RP2040 is powered by the Raspberry Pi Foundation's RP2040 microcontroller, a dual-core 133MHz ARM Cortex-M0+ processor. Supports synchronous and asynchronous transfers, with read speeds up to 9 megabytes/second, and write speeds up to 6 megabytes per second. A SCSI controller with FAST SCSI and synchronous mode is required to achieve maximum speeds.
ZuluSCSI firmware is open-source, licensed under the GPLv3. See http://github.com/zuluscsi/zuluscsi-firmware or ZuluSCSI.com for more information.
ZuluSCSI Compact board dimensions are 90mm by 60cm. Nearly all mounting solutions that were designed for SCSI2SD V5.1/V5.2/V6, or the full-sized ZuluSCSI boards, will work just as well with ZuluSCSI Compact. The two front mounting holes on ZuluSCSI Compact are the same dimensions.
