I didn't notice anything else outside of the corner distortion being fixed. But that's the only problem I had with the monitor. Everything else was fine.
I think the below is the list but note that I did the Apple 16" Monitor as well as this M1297 13" around the same time so I'm not positive. You should probably double check. I also don't remember if M0401 and M1297 were the separate revisions or whether even within the M1297 there were multiple revisions so another reason to double check with what you actually see on the boards. I'm copying these from my notepad so hopefully don't make a mistake in translation. Apologize for the lack of sorting on the cap numbers but I had jotted this down as I canvased the board so it's not in numerical order. The size is diameter first followed by height in millimeters.
- Board B
- C015 - 10uF 50V 85C 5x11
- C013 - 2.2uF 160V 105C 8x12
- C036 - 10uF 250V 85C 13x20
- C025 - 10uF 50V 85C 5x11
- C007 - 47uF 50V 85C 6x11
- C023 - 2.2uF 160V 85C 8x12
- C033 - 2.2uF 160V 85C 8x12
- C035 - 10uF 50V 85C 5x11
- C038 - 47uF 100V 85C 10x16
- C008 - 47uF 50V 85C 6x11
- C950 - 100uF 25V 85C 6x11
- Board D
- C547 - 1uF 160V 105C 8x14
- C529 - 100uF 35V 105C 7x12
- C524 - 470uF 35V 85C 10x20
- C570 - 100uF 25V 85C 6x11
- C592 - 100uF 16V 85C 6x12
- C591 - 100uF 25V 85C 6x11
- C572 - 100uF 16V 85C 6x12
- C569 - 100uF 25V 85C 6x11
- C568 - 470uF 35V 85C 10x20
- C581 - 22uF 250V 85C 13x25
- C575 - 33uF 160V 85C 16x25
- C586 - 47uF 16V 85C 5x12
- C587 - 47uF 16V 85C 5x12
- C516 - 10uF 50V 85C 5x11
- C526 - 4.7uF 50V 85C 5x11
- C530 - 10uF 50V 85C 5x11
- C519 - 22uF 25V 85C 5x11
- C520 - 1uF 50V 85C 5x11
- C523 - 1uF 50V 85C 5x11
- C501 - 1uF 50V 85C 5x11
- C531 - 470uF 16V 85C 10x12
- C597 - 0.47uF 50V 85C 5x11 BIPOLAR
- C511 - 3.3uF 50V 85C 5x11
- C510 - 4.7uF 50V 85C 5x11
- C505 - 1uF 50V 85C 5x11
- C506 - 1uF 50V 85C 5x11
- C512 - 4.7uF 50V 85C 6x11 BIPOLAR
- C513 - 33uF 16V 85C 5x11
- C517 - 2.2uF 50V 85C 5x10
- C588 - 4.7uF 50V 85C 5x10
- C595 - 2.2uF 50V 85C 5x10
- C594 - 2.2uF 50V 85C 5x10
- C599 - 4.7uF 50V 85C 5x10
- C546 - 100uF 16V 85C 6x11
- Power Supply Board
- C107 - 470uF 400V 85C 35x41
- C108 - 4.7uF 350V 105C 16x26
- C109 - 4.7uF 350V 105C 16x26
- C113 - 22uF 50V 85C 5x11
- C216 - 4.7uF 50V 85C 5x11
- C215 - 22uF 50V 85C 5x11
- C209 - 47uF 25V 85C 5x11
- C210 - 47uF 25V 85C 5x11
- C205 - 33uF 160V 85C 13x20
- C203 - 100uF 160V 85C 16x26
- C206 - 22uF 100V 85C 8x11
- C204 - 470uF 100V 85C 16x31
- C218 - 100uF 25V 85C 6x11
- C219 - 100uF 25V 85C 6x11
Again, you should double check these as you're pulling the old ones off the board just in case. But hope this helps.
