This is a bizarre one. I can’t get my newly flashed Radeon 7000 PCI to work in my beige G3 when I have a Yikes G4 ZIF installed.
The problem only occurs with the ATi extensions installed. It locks up when the CPU Director extension tries to enable the cache. If I disable the CPU Director extension, then it gets as far as the menu bar appearing before locking up. If I disable
the ATi Resource Manager extension, then everything is fine (but no 2D acceleration).
If I put back in my G3 ZIF in the beige, all works great.
The R7000 also does not have this issue in the Yikes machine with the same CPU.
Any ideas what could be going on here?
