Powerbook 2400c inverter
Working on a powerbook 2400c I thought it had a bad backlight so I replace the bulb but still no backlight bought a tester for the bulb and confirm it's working so I supect it's the inverter board so I figured I ask a few questions. in the attach picture does anyone know if F1 is a fuse? It look like it marked 1.25A ? 73 I checked and it doesn't have continuity. Second question second picture on transformer should I have conitunity between the two right soldered connection. lastly open to any suggestion on things to check/testing. Thanks in advance.
Following in case you figure this out, I've got several of these that could use repair. Seems to be a failure-prone part.
I think your right since I have two and both aren't working. I'm almost wondering if I could wire-in a replacement inverter or I guess I could permanently attach the tester to the powerbook.
I think to narrow problems down quicker one should have one working machine and swap part for part.
its enerving..like the 3400s
Where did you find a replacement bulb? Trying to track down similar issues on mine.
Parts for these are pretty much unobtanium, you have to just grab them when they come up which is rarely, I have a pretty large stash of parts for these machines I'll be liquidating at some point when I have time to go through and build out the best units.
I’ll mention replacing the bulb isn’t too difficult but I would suggest getting a tester if your not positive the bulb is bad
Thank you for the info - super helpful. I did verify the bulb on mine is bad. Has a really pronounced red tint to it, indicating it's on its way out.
I take it the controller board has to be moved out of place to access the bulb? Trying to avoid messing with this panel as much as I can due to how rare they seem to be.
I'll take a few picture and post them later today I bought bulbs from this seller tvrepairledtester listed as follows I have extras if you want a couple send me a PM I'll be happy to send you two if you cover the shipping.
220mm*2mm CCFL Backlight Lamps for 10.4'' Laptop LCD Monitor Brand New​
Here are some pictures of removing the backlight remove the three circled screws this should allow you to remove the metal frame around the front of the screen
next remove these screws and you can pull back the controller board there's and edge connector under the arrow so you'll need to pry that loose
peel the controller board back pull the back light out remove the light and solder new bulb in
I just got a 2400c/240 and it’s display is smashed. The backlight doesn’t turn on through and brightness controls don’t change it either. I was wondering could this be a bad inverter or backlight? Is there any way to know which without a bulb tester?
I just got a 2400c/240 and its display is smashed. The backlight doesn’t turn on through and brightness controls don’t change it either. I was wondering could this be a bad inverter or backlight? Is there any way to know which without a bulb tester?
Not PowerBook specific but I seen videos where people hook up backlights to a working laptop’s inverter to test. The tester I got was pretty cheap on Amazon currently $10 but you need to use you own 12volt power supply.
I don’t think I have any other inverters that would work. Voltage is 0v going to the backlight. I need to try to get a display and inverter now it seems which is going to be difficult.
It does it seems like this is a point of failure for this model and finding parts is difficult. I’m in the same boat.
Would there be any way to use a new inverter or wire direct power to the backlight? I’m not sure what else the inverter does but I Might just do that if it only powers the backlight
