Well it is your thread, so if you say it counts, it counts!
That works for me!
I scored a current-model Sony CFD-S70 for $10
I looked that up. It looks like a nice, compact boombox that has all the basics covered pretty well. I'd be tempted to get one if I didn't already have a bunch of them (in addition to the CFS-6000, I have a couple other Sony boomboxes, plus probably a few others hidden away somewhere in storage).
I tinkered with the tape player some more, and I got it to work! It's bi-directional with auto-reverse, and apparently the reversing mechanism got jammed, and by messing with fast forward and rewind, I somehow got it unstuck. I should probably look into changing the belts and regreasing things, because fast forward doesn't seem to be working (play and rewind seem to work fine though. I won't dare try the reversing feature, lest it get stuck again). It's also making some odd clicking noises, which concerns me, but it's more or less working?.
I'm listening to some
old tapes I made 20-25 years ago, and it sounds decent enough.
Overall I'm pleased. It's too bad AM Stereo didn't take off more, because under good conditions, it sounds
really good!
I was just looking at it, and upon closer inspection, this unit seems like it saw relatively little use. It's kind of grimy and dirty with the usual scuffs and scratches, but there's very little wear and tear otherwise, like someone just bought it, sat it on a shelf and used it once in awhile.
c
