Yup. I don't know what it is - I think it must be the way that MacOS does power saving on the WiFi or something? Transfer rates from mini vmac over wifi are wildly inconsistent despite the application neither knowing nor caring that it's on wifi
Do you guys think it would be possible to condense this on a modem adapter port for a l'ebook 100 series? My idea i just to drop the rs422 transceiver and connect the pic directly to the serial port. It would be basically like connecting AirTalk to a device with a serial cable, but never using rs422. I checked the powerbook 100 schematics and the both serial ports go to two ports on the serial controller ic, the only difference is that the external serial port has the 422 transceiver on it.
What do you think?
but having a wireless powerbook seems fun!
As I recall, only one of the two ports on the SCC supports LocalTalk, wouldn't that be the external one?I checked the powerbook 100 schematics and the both serial ports go to two ports on the serial controller ic, the only difference is that the external serial port has the 422 transceiver on it.
using a patched driver that shows the modem port could work.
@sfiera 's MultiTalk can do it:Is the a program that can bridge LToUDP to EtherTalk?
I think you mean "TashTalk"... I'm "the Tashtari" and nobody listens to me. ;Dhow does netatalk get configured to listen to the tashtari?
Thanks for making such a fun and awesome piece of kit!
I even compiled Mini VMac with the LTO UDP option for PocketCHIP (the Linux handheld from a few years ago). I made a blog post about that if anyone is curious.
Is this normal? What does the Err light indicate on the LT side?
If you're curious, every time the red LT LED lights up, it should emit a log message out of the UART. You should be able to spot the UART spot on the AirTalk board: the pins are labelled, and it should talk reasonably happily to any USB serialish adapter that can do 3.3V levels. The cases where the red LT LED lights can be found in the firmware with this search: https://github.com/search?q=repo:cheesestraws/airtalk LT_RED_LED&type=code
