Two SEs & Accessories - $300
jdcurry
Had been looking for an SE (specifically an SE/30 but no dice) on and off for a while but nothing but high-priced eBay items were really popping up for me. Checked my local Craigslist and apparently someone was selling two units for $200. One is functional, and the other one displays the black and white bars. The bag, mouse & keyboard cost an extra $100. I almost said no thanks, (and maybe a bit overpriced) but I had some cash squared away from selling a used car many months ago, so I figured what the heck.
They're both quite yellowed, one has some numbers scratched onto it (bummer!) with some minor rust spots around the floppy drives and ports. I don't think the previous owner stored them in decent controlled environments (apparently they came from his barn) Nothing that can't be cleaned up or retro-brightened, I think...
One seems to have a modem of some kind. Looks like a bnc connector/serial port? He also mentioned one (or both) units had RAM upgrades at some point. I have yet to open them up and see for myself. I pre-purchased the BMOW ROM Initiatior (which I read will NOT work with an SE) so... I may need to return it or see if someone on here wants it.
What options do I have for replacing hard drives with an SE? And what options do I have for permanently installing a ROM disk? (I do have a BMOW disk emulator which I think works with a standard SE so I don't believe I need to purchase a scsi2sd adapter) I know there are big differences between the SE and SE/30 but I'm trying to keep an upbeat attitude despite thinking I was getting two SE/30s. (To be fair it was listed properly on Craigslist so no fault on the seller's part)
The biggest challenge will be replacing the caps since my soldering skills are not good and I need practice before attempting to work on these. I've read in some places the SE has fewer issues with cap leakage than the SE/30 but I want to play it safe and I don't have definitive proof of that claim. I haven't found what caps should be replaced on an SE board... but I have found kits for the SE/30 -- which I don't believe will help me. If someone can link me to what caps I should get for SE boards, would greatly appreciate it.
Considering what these go for on eBay (whether functional or not) I think this was a good deal overall. And I should be able to play some of the old classic games I grew up with, even considering the limitations of the SE compared to the SE/30.
Here are some pictures for your enjoyment:
No, seriously, you don't need to recap SEs unless they're actually showing issues. It isn't playing it safe, there is more chance of damage from recapping. They don't have the same type of capacitors. The major issues are with SMD electrolytics, the SE doesn't have a single one of those.
You do need to get the batteries out urgently though.
Okay, thanks for that. I have a long screwdriver coming via amazon tomorrow so I can open them up. Can you recommend what batteries I should purchase to replace them?
BTW, that keyboard is highly desirable and sought after. It is a IIgs Keyboard. Don't let anyone make a $50 offer in your DMs.
I'd consider running it without one to be honest. But you want to see what they have fitted first, they came with two types of battery.
Here is my other keyboard which I think uses the same port? It appears newer and probably not as collectible. IMG_8218.jpg
Oh, I didn't know you could do that. I'd be happy leaving them battery-less if that's an option.
Curious, is that keyboard the same one that would have came with the unit? Or for a different machine?
Different machine, it's for an Apple IIgs, not a Macintosh at all. It works with Macs though. Uses the same ADB protocol.
The other one isn't original either and is about 7 or so years newer than the computers.
Interesting. I guess I'll consider myself lucky (if it works). Seller didn't seem to know when I asked.
The SE was usually sold with either a M0115, M0116, M0487, or M3501 keyboard, depending on when it was sold.
Battery-wise, if the motherboards are early enough, they would have the soldered on Varta batteries. I would clip them out, then, if you want to keep your settings, go over to the ReActiveMicro website and get the Apple IIgs battery adapter they sell for $10, plus shipping, PayPal fees, etc. Has two wires that connect to the wires on the board, then a double AAA battery holder. Pop two Energizer Ultimate Lithiums into the holder, and it'll work like it did with the original battery.
Hard drive-wise, I do have a 40MB SCSI drive from my LCIII which would work. Has System 7.5 installed on it. I'd be tempted to downgrade it to 6.0.8, though, which I could do for you, if you want it.
