Power Mac 7500
This is a very heavily upgraded machine. You want to look after it. Be careful with the cards and RAM. Don't touch the edge contacts and put them down on cardboard or paper, not plastic or synthetic cloth.
Right. I fetched my 8600 out of storage, it is basically the same logic board as your 7500, close enough to not matter.
My 8600 boots happily using the ixMicro PCI video card I have installed with no VRAM installed on the logic board, so that is not your problem.
So, you should have your computer set up as follows.
  • Only 1 RAM SIMM
  • Remove the SCSI Hard Disk PCI card
  • Unplug the data and power cables from both hard disks
  • Remove the battery
  • An external speaker plugged into the sound out port (not the microphone, triple check!). Verify the speaker works and is turned up.
This is your base test setup. This is sort of a minimum. The other stuff only complicates things.
Test the computer. Does it chime?
If not, remove the CPU card and carefully, using rubbing alcohol on a q-tip or paper towel, scrub the gold contacts. Do not touch them with your fingers. Do not wear high-static clothes. Do not take off a staticy pullover just before handling the computer.
Put the CPU back in the computer. They take quite a bit of effort to push in all the way, do not leave it slightly out. Triple check. I killed a 500MHz G4 Sonnet once because it wasn't quite fully seated. Make sure it is properly in place. Square and all the way down. I can not over emphasise this enough. You're sure? Well check it again.
Try the computer. Does it chime through the external speaker that you remembered to power on?
If not, remove the PCI video card.
Again, try the computer (with no video card). Does it chime?
My 8600 will chime with no VRAM on the logic board, and no PCI video card. Although it isn't very useful like this ;)
After these tests, let us know how everything is.
I've also found carefully scrubbing the contacts with an eraser really helps although contact cleaner works better than any of it, I had a couple cards I cleaned by eraser, and alcohol and nada, got some contact cleaner and instantly in business. I've quite a few of these machines and I agree that your issues is either the CPU or your memory. I'd pick one memory stick to try and give it the same treatment you give the CPU if just cleaning the CPU does not work. If that doesn't work, swap your memory with another stick keeping everything else the same and give that second memory stick a good clean on the contacts before trying it.
And if none of that works, then buy a can of contact cleaner and spray the inside of the PCI slot where the video card is, the cpu slot, and the memory slot, then let it dry for a good long time overnight is overkill but a safe time frame if you do it just before bed then try it all again.
  • Only 1 RAM SIMM
Did all your steps. When taking out the cpu card to clean It i found that it wasn’t in all the way. Reseated it and cleaned the cards memory and the cpu. Nothing different happened.
