7500 with display resolution issues
i have a 7500/100 with a sonnet crescendo G3 400/512 upgrade
i am using a scsi2sd card from a previous working 7500 system - and can boot into 9.2.2 or 7.6
when i first put the scsi2sd card in the system i booted to 7.6 and was able to set display resolution from a big selection (i am using a dell p170sf with a vga adapter)
but on restart only 640x480 is available. i booted into 9.2.2 and was able to select higher resolutions again, but upon restart, same issue - only 640x480 is available.
this 7500 has the AV module installed, but i dont think i have any extensions on control panels that allow me to access it (i didnt use a 7500 AV specific install, so i don't think it knows how to access the module?) - however the original HDD (running 8.5) that the 7500 came with had a control strip that let you select audio/video input. im wondering if there is some weirdness with the resolution selection and the AV module? i didnt have this resolution issue with my previous 7500 and this scsi2sd setup, but i also dont remember if that one had the AV module installed - but unplugging it doesn't seem to change the issue i am having.
during my trouble shooting, i disabled the ˚AppleVision extension and when i restarted i was able to select 1024 and higher resolutions again, but once again when i restarted i was forced back to 640x480 with no other choices. bit depth lets me choose up to millions of colors, but resolution is fixed. i just left applevision disabled in the meantime.
is there a utility that lets the system check vram? i am pretty sure the 4mb vram i have installed is okay, since i can display larger resolutions fine some of the time - maybe the vram access is on the fritz and only working some of the time? recapping needed?
i am perplexed...
Hi systemseven,
I suspect it's your DB15 - VGA adapter forcing 640 x 480 resolution from startup each time, there are adapters that let you force higher resolutions. It might also be a good time for a PRAM reset, and maybe an OS reinstall.
