Macintosh se Mobius SpeedScreen se
Hi to all,
Six Years ago i posted if someone had the init and control panel for a mobius speedscreen se, i never found those driver, maybe in six years someone had a better luck and can help me.
Thanks in advance and best Regards.
Vincent.
Yes, they are for the mobius 030 accelerator, the speedscreen se it's a 68k 16 mhz accelerator with a full page dysplay output.
Have you tried the Mobius Video driver from there? I thought were drivers for multiple Mobius cards there, must be thinking of something else.
I'd suggest trying the GemStart driver for the processor bit, they work with some Mobius upgrades.
Have you tried the Mobius Video driver from there? I thought were drivers for multiple Mobius cards there, must be thinking odlf something else.
Ok i give it a try.
Thanks
What happens, because most SE accelerators sort of work even without drivers?
I used tattletech to analise but didn't found anything about the hardware, but when i installed ramdoubler, the software alert to me that he can't start the ramdoubler because of an accelerator installed.
I don't understand what you're saying. TattleTech tells you what processor is being used on the tab that opens on launch.
thanks i'll doing but wait norton 3.1.3 ifor system 7 i had system 6.0.8, maybe system info works under system 6
Ah sorry, I forgot you were running System 6. Try this :
ok i'll try, meanwhile i found some info on a format magazine named macworld from 1991 that mention mobius one page dysplay had a 68000 16 mhz processor board an external output for a second monitor and the possybility to install a coprocessor fpu 68881 but the name of the card was mobius one page dysplay may
Ok i give it a try.
Thanks
So the video control panel that comes with the Mobius drivers didn't work? I have the Mobius 030 in my SE with video out and it is working with the drivers from https://vintageapple.org/macdrivers/accel.shtml.
Weird, I can't find advertisements for this card, usually when I search the internet archive I can find something, but no hits so far. What I did find in mention of something just called "the mobius card", which sounds like it may be the same card, or it's predecessor.
I just posted a bunch of drivers for the NewLife cards on my site, they also have video output. I doubt they'd work but it's worth a try.
Hi and thanks,
i'm tryng to download the new life driver from your site but theres an error with the download.
