Not sure if it is pertinent, but looking at @BadGoldEagle's screenshot, as well as the language, is the font size on file names non-standard? What other UI tweaks are there?Awesome feedback thanks, clearly I have some debugging to do …. @MindWalker I think I know what’s causing that, double checking are you running with 256 colors by chance?
@BadGoldEagle what System version are you running here?
<Edit>
I can see Power Windows for a start.
</Edit>
The finder view setting doesn't quite look... normal... either, but then I'm a creature if habit and might just not be used to options I don't use.
