So I was hoping to enter the "Portables Week" contest over on Reddit with my beautiful backlit Macintosh Portable. I ran over to my storage locker and grabbed the Portable this morning and fired it up with my SCSI2SD connected to the external SCSI port. I should note that this Portable has a re-celled battery and recapped motherboard obtained from @haplain 7-8 years ago, and also has a fresh 9-volt battery installed, and as recently as 1-2 years ago it was running well.
Pretty quickly I noticed some weird stuff going on today:
Any idea what's going on? As best I am aware, the power supply itself was never recapped - would that cause any / all of this behavior? For whatever it's worth, I gently opened the machine and re-seated all the internal cards, but that didn't seem to make much difference.
Thanks for any ideas!
Huxley
- It would start to boot into a default / generic System 7.5.3 config but would crash shortly after the boot process begins, usually with an "Address Error" message
- Booting into System 7.5.3 without any extensions loaded worked fine, but System 7.5.3 without extensions isn't super useful
- Booting into System 6.0.8 works fine... most of the time. Once in a while it bombs out with a Sad Mac error and 'chimes of death,' but hitting the Reset button usually gets it going
- Any attempt to initiate my SimpleWiFi232 device on the Modem port using Zterm 0.9 immediately crashes the machine, upon which it will reboot and load the Desktop but in a frozen state - I have to press the reset button to get back to operation. I only noticed this because I thought "huh, maybe this old version of Zterm has a bug on the Portable" so I used my Performa 575 to copy Zterm 1.0.1 onto a floppy disk... which instantly crashes the Portable upon insertion
- Also weird: the backlight seems to be behaving very strangely - sometimes it comes on bright and steady, other times it's dim, and sometimes it's off entirely until I reboot the machine
- Even weirder: inserting a floppy disk simultaneously makes the backlight immediately turn on and immediately hard-crashes the machine, and once it crashes / reboots, it goes into a boot-loop, chiming over and over again until I eject the floppy disk by holding the mouse button down
Huxley
