I have nothing of substance to add
I just want to say this is wonderful and ambitious. Nice work!
Same, keep it up! That's a rough rough system, and I applaud you for taking the effort and time to restore it.I have nothing of substance to addI just want to say this is wonderful and ambitious. Nice work!
Thank you both for the very kind words!Same, keep it up! That's a rough rough system, and I applaud you for taking the effort and time to restore it.
Don't use this on the rod, just a drop of silicone if you have access to it.white lithium grease
Saw that in a video also for disk ii cleaning, I might have to buy some if needed. I'll see how well the movement is once out of the rust bathDon't use this on the rod, just a drop of silicone if you have access to it.
The light on the keyboard? Or elsewhere? If so.. man that's a terrible design lolIIRC, the Apple III doesn't work if the light bulb fails...
All I have is a fluke mutli meter at the moment, if needed I can get a tester pen. Have a recommended one?Have you got a Logic analyser ? even a tester pen ? troubleshooting the board is not an easy task without some tools.
At least you know the board is doing something
Not really what is needed here, more something like that :Was looking at the fluke 20-90
