Dead SE/30 Power Supply (no fan, no voltages at floppy connector)
I grabbed an SE/30 from Craigslist tonight which was sold as dead. Returning home, I found a couple of things:
- The motherboard was actually in good shape, with no obvious major battery or capacitor leakage. That said, one of the vias by the battery (just one!) was green and corroded, although this is easy to fix.
- The more major problem is that the machine doesn't power up at all - there's no fan activity, and I can't see any voltage at the floppy connector.
Before I tear it all down - the power supply is made by Sony, and I can't seem to find any reference online to actually repairing it. I'm also assuming it's a switched model - is it fixable, or should I be hunting for a working unit?
The power supply probably needs recapping. The Sony CR-44 is a universal switching power supply. Or you can replace the internals of it with an ATX PSU and do a conversion (as the wiring does not match up).
Also worth checking the fuse on the power supply, if it's blown then something else is wrong and will need to be fixed first.
The caps needed for the Sony are listed here:
You can buy a kit from here, or alternatively buy from a parts supplier such as Mouser.
I'd also check all the connector joints on the analog board, if the connector from the power supply to the AB has bad solder joints you won't get any power to the logic board.
Check the voltages at the power connector on the logic board too with it switched on.
Thanks! I've extracted the analog power and power supply and will look for cold joints. Initially, though, the internal fuse seems good though. Otherwise, does the power supply need a specific load to be tested in isolation, or will the rails come up without one?
You don’t need a load to test the PSU, but the voltages won’t be right until you do. @JDW have a nice video about it on YouTube. Much better if it’s just the switch, though :-)
The switch you need is made by Marquardt 1802.6123 - I bought some recently from Mouser Electronics. Appears to be the original part.
Hi there,
I hope I can use this thread... I've got exactly a same issue with a Mac Classic. No power at all, no screen, no fan nothing when I switch on. I've recapped already a part of the PSU but still nothing. I would like to know from where I must start for voltage controls, control points etc. Thanks a lot for him beforehand. Kind regards.
Hi there,
You should better open a new post...
Check this IC and the MOSFET next to it. Could be the culprit.
Thanks a lot spending time to help me. Very much appreciated. I don't know how to copy/paste in a new post, maybe a moderator will do for us ?
So, I've just found a CR-44 schematics but seems this is not exactly the same...at least components haven't the same names :-(
https://museo.freaknet.org/gallery/apple/stuff/mac/andreas.kann/SE_Netzteil.GIF
In the meantime I recapped the 2 missing capacitors of the recommendation picture below. I've checked voltage out of the diode bridge : 315V DC
Still absolutely nothing happen when I switch power on...
I haven't recapped the 2 big 220uF/400V next to the power switch.
What IC do you mean ? the 8 pins TDA ? What is the mosfet close to it ? sorry I'm a newbie but with a true strong wish to learn! And I promise to be a good student. In order to start, I looked for datasheets :
IP1 is TDA 4605 : https://pdf1.alldatasheet.fr/datasheet-pdf/view/25064/STMICROELECTRONICS/TDA4605.html
QP2 is MTP 6N60 : https://pdf1.alldatasheet.fr/datasheet-pdf/view/23383/STMICROELECTRONICS/MTP6N60.html
if so How can I check them ?
Thanks a lot again :love:
Stéphane
Hi again, In the meantime I've checked supply voltage between pin4 and pin6 of the TDA4605 and found about 11,15V DC which I think is correct ? Thanks again for your kind help
11.15 is low, it should be 12v. Could just have to be adjusted but with how unreliable these boards are it could be another failed part.
IIRC this is AC and not DC.
11.15 is low... probably the usual suspects, DP4 and DP3 (1N4148 diodes) are leaky and to be replaced, but all in all 11 volts is the minimum required for switch-on voltage.
1665737270764.png Hi bibilit, Voltage between pin4/ground and 6/supply voltage is AC ? and not DC? thanks
Yes AC not DC as this part is on the primary side
(4) is ground and (6) 12 volt AC
pin (5) goes to the Mosfet (QP2 / IRFEC 40)
If the Mosfet is gone, the fuse will blow probably.
Also worth checking the Optocoupler QP1 (CNY 17)
But replace the two diodes first, by far the cheapest units and to be replaced as a matter of fact, most not working units are due to those two diodes (not shorted, simply leaking)
So I've rechecked and between pin 4 and pin 6 I've almost NOTHING AC !! but only 11,2V DC ! maybe it could help to diagnostic even I cannot understand we are AC on this side after the diode bridge (newbie I am!)
Besides,
* how could I check QP1 optocoupler ? I have an oscilloscope if needed.
* what are the 2 diodes I need to replace ?
With 68000 thanks again,
Stéphane
