I recently installed Bolle's TwinSpark Clone with an original MicroMac Carrera card in my SE/30. I got it work but the CPU caps out at 32Mhz. I have the correct CPU, but am wondering if I need to upgrade my PSU. Am I on the right track?
The clock speed is fixed by the clock on the board. On those I think the processor runs at doublehalf half or double the clock speed. I think you most likely have a 33MHz board. If you look near the bottom left of the board you'll see a shiny metal component with "66" or similar written on it.
Ah right, your's does double the clock then. A 32MHz 040 is pretty quick in an SE/30 anyhow. At most 21% difference, but in reality closer because they're both restricted by the 16MHz bus.
