I have on hand two non-funtioning LIsa models. So far, I've not had the opportunity for more than a quick look at both, and I didn't have the chance to capture the Serial Numbers (though I'll try to do that later).
The first had a Battery Pack which, unfortunately, had not been removed (I have now removed it), and has corrosion on a few traces, and several components. This one has bodge wires on the Logic Board, and a chip marked "Sun Remarking," which leads me to suspect it's a Lisa 2 that was upgraded in some way.
The second has no Battery Pack (and no Bodge Wires), and doesn't have too much in the way of obvious damage (though this is just from looking in the back). This seems to be a Lisa 2/10 or Mac XL.
Anything I should be looking for that would be useful to know, apart from the Serial Numbers?
Thanks!
Thanks!
